Posts: 16,241 Likes: 234
Posts: 16,241 Likes: 234 |
Dein Auto ist bei weitem Schlauer als erwartet, erstaunlich dass du das nicht beim Fahren bemerkst. Ich hab dir hier das Englische original. tow mode changes a variety of parameters. A forum user either here on the 6.0 forum that knows a lot more about the 5r posted up most of them a while ago. Apparently in addition to changing the shift patterns, it also changes line pressure, slip at the torque converter, and affects the variable vanes of the turbo to provide maximum torque and engine braking, and it does so in conjunction with the coast clutch on the transmission.
The tow/haul will not keep your truck out of overdrive on the highway, for some reason that is a common misconception. I drive with mine engaged while towing and do most of my driving in overdrive on the interstate. Basically, though, on the power side, it will let you throttle up higher at idle, it will hold each gear for longer, it will shift harder (which protects the transmission), it will allow you to give more throttle in each gear before downshifting, and it will hold downshifts until you pull the hill. On the braking side, it will give you maximum engine braking by using the vanes of the turbo and the coast clutch, which means on hills you don't have to touch the brakes except to knock it down a gear if it starts to gain speed, and in stop and go traffic instead of driving with your left foot on the brake, you just lift the throttle and the truck instantly starts to retard its speed, without touching the brakes. Its so nice that I use it in stop and go traffic even when I'm not towing. But really, until you tow something heavy you won't fully appreciate it. Run with it and run without it, it makes a big difference in towing, especially if you don't have much experience towing heavy things. Quelle > https://www.ford-trucks.com/forums/1153078-6-0-tow-mode.htmlIm übrigen ein gutes Forum, dieser Mark Kowalsky hat wohl bei Ford in der Getriebentwicklung gearbeitet zu der Zeit als Deiner gebaut wurde. Interessant.
Posts: 8,093 Likes: 115
Posts: 8,093 Likes: 115 |
Posts: 14,355 Likes: 27
Posts: 14,355 Likes: 27 |
Da fehlt noch das Hinweisschild "Seife".
Posts: 646 Likes: 24
Posts: 646 Likes: 24 |
Nochmal zurück zum Tow/Haul Modus. Ich benutze den immer öfter. Zuerst war ich auch der Meinung da sei kein grosser Unterschied mit oder ohne...die Meinung musste ich in den letzten zweieinhalb Wochen gründlich revidieren. War wieder etwas unterwegs, 5400 km, dabei den einen oder anderen Pass unter die Räder genommen, 145124m Höhenmeter rauf und ebensoviele wieder runter (sollte genug sein damit meine neuen Bremsen eingefahren sind ). Grundsätzlich bin ich Deiner Meinung dass Bremsklötze billiger als ein Getriebe/Antriebswelle sind (darum hab ich meine ja auch vor kurzem kaputtgefahren, aber das waren etwas andere Gründe und ist eine andere, längere Geschichte), aber bei einem 2800m-Pass will man bei 5 oder 6 Tonnen nicht die ganze Zeit auf den Eisen stehen, denn irgendwann, meistens wenn man sie dringend benötigt, hat man wegen Ãœberhitzung dann gar keine Bremsen. Also einen oder 2 (oder auch mehr) Gänge herunterschalten, damit der Motor/Getriebe mitbremst...habe ich sogar bei uns in den Bergen in der Fahrschule so gelernt. Bei einem Schaltgetriebe sehe ich es auch nicht ein warum man das nicht so machen sollte, oder was dabei kaputtgehen sollte. Auch beim Automaten denke ich dass die für die Kräfte ausgelegt sind und grundsätzlich dafür gebaut sind. Was ich tunlichst vermeide ist bergab die Gänge manuell runterzuschalten ohne vorher mit der Fussbremse runterzubremsen. Das würde ansonsten nämlich voll auf die Kupplungen gehen, was sicher nicht zu deren Lebensdauer beitragen würde. Im Automatischem Betrieb kommt genau da der T/H-Mode zum tragen. Genau dafür ist die erhöhte Line Pressure, welche die Schaltzeiten (und somit das schleifen der Kupplungen) wesentlich verkürzt, das auf kosten des Fahrkomforts da die Gänge etwas weniger sanft eingelegt werden, wobei das -bei meinem zumindest- jammern auf sehr hohem Niveau ist. Desweiteren schaltet meiner bis in den 2 runter wenn nötig. Sagen wir ich fahre 60, werde immer schneller, bremse auf 60 ab, werde immer noch schneller, bremse ein 2 mal und da schaltet er bei mir soweit runter und hält so die Geschwindigkeit knallhart (sofern der 2 Gang dafür nicht zu lange ist) bis ich wieder gas gebe, dann schaltet er nach einiger Zeit wieder rauf. Damit kann man sehr Bremsen- und Getriebeschonend bergab fahren...zumindest bis 15 oder 18 Grad Gefälle...Steiler ist dann sowieso eine andere Baustelle und bedarf anderer Methoden... Auch Bergauf fahre ich gerne mit T/H-Mode. Hält einerseits die Drehzahl höher, andererseits habe ich das Gefühl dass das Getriebe dabei kühler läuft, da dabei vermutlich die TCC länger aktiv bleibt, aber so richtig hab ich die dahinter verborgenen Algorythmen noch nicht kapiert. Bergauf bringe ich mit T/H-Mode ein ca 15-20 Grad kühleres Getriebe hin (meistens bei 80-90 Grad statt 100 und mehr Grad), Kehrseite der Medaille: Mehrverbrauch, sowohl Bergauf als auch Bergab, damit kann ich aber leben. Mein Rat: Auf einer etwas steileren Passstrasse mal ausprobieren...ich hatte es bisher auch eher im Flachland ausprobiert und da waren die Unterschiede marginal bis nicht bemerkbar.
Der Kabinenbauer
Der Kabinenbauer
Posts: 120 |
Hartwig,
ich war ja so lange nicht im Forum... hatte keine Ahnung von Deinem Dilemma - boah, das tut ja echt weh! Du hast so sauber gearbeitet... und jetzt der Zirkus, das hast Du wirklich nicht verdient! Toi, toi, toi - ich habe noch keine einzige Delamination bei den Platten meines Herstellers erlebt, hoffe es bleibt so.
Alles Gute!
Gruss, Jürgen (Explorer II) RAM 2500 HD CC 4x4 SLT 5.7L HEMI, SimplexCamper KAB, AEV Salta 8.5x17 ET 27, 37x12.5 R17 Cooper Disco. STT Pro, MOPAR Fender-Flares, ClimAir, Alcantara-Lenkrad, Steps, Cab-Lights, Lazer T-24 & ST-6, Rhino-Rack, Sitzheizung, AEV Snorkel, AEV 3" DualSport, Hundebox
Seit etlichen Wochen versucht mein Vericherungsmakler die Änderung von LKW auf WOMO mit entsprechender Kaskoerhöhung bei der AXA bestätigt zu kommen. Sie haben einfach nicht reagiert, bei Anrufen kamen lächerliche Ausreden. Seit heute weiß ich warum: " Sehr geehrter Herr *Name meines Vers.-maklers*, Sie reichten uns das o.a. Gutachten zu dem Campingfahrzeug unseres gemeinsamen Kunden Herrn Heil ein. Der Zeitwert hat sich aufgrund des Umbaus von 23000,00 Euro auf 110000,00 Euro erhöht, weshalb wir das Risiko als auch die Kundenverbindung erneut prüfen mussten. Leider ist Herr HEIL HARTWIG kein Rund-um-Kunde bei uns ("4SUHK-Verträge/1500 Euro Jahresausgleichsgeschäft und Schaden- quote besser als 65%), sodass wir für das Campingfahrzeug aufgrund der massiven Werterhöhung keine Kasko mehr anbieten können. Bitte heben Sie den Vertrag zum Jahresende oder per sofort auf (da momentan das Fahrzeug nur zum alten Wert versichert ist), damit der Kunde die Möglichkeit hat, sich bei einem anderen Versicherer ein zu decken. Ich bitte um Ihr Verständnis. Freundlich grüßt Sie Ilka Marliani Underwriter SUHK-Kraftfahrt Geschäftsteuerung 1 AXA Versicherung Willstätterstraße 62 40549 Düsseldorf Tel.: 0221 148-51112 axa.de " Diese elenden Hurensöhne könnten das doch gleich sagen daß denen die Klammer geht, Dreckspack elendiges.
Posts: 1,443 Likes: 23
Posts: 1,443 Likes: 23 |
Ich versehe nicht, was du hast?
Das sind doch gaanz normale Versicherungsheinis:
"Sparen, wos geht"
"Ich habe doch nichts zu verschenken"
Und was glaubst Du, mit welchem Geld die ihre Glas-Marmor-Designer-Großkotz-Angeber Paläste bauen?
Und "irgendwer" muss doch auch die vielen Sponsor- und Werbeaktivitäten bezahlen! Ist diese bunt leuchtende Designerkugel in München, in der auch manchmal Fußball gespielt wird, nicht auch nach einer Versicherung (oder Bank, aber das sind ja eh dieselben Verbrecher) benannt??
Das Zitat "Was ist schon ein Bankraub gegen die Gründung einer Bank" kann man sinngemäß auch auf die Gründung einer Vesicherung ummünzen.
Von den Gehältern wollen wir gleich gar nicht anfangen!!
Das ist leider die Realität! Schone dein Herz und Deine Magennerven und ärgere dich nicht! Hau irgendwo - wo es nichts kostet und nicht weh tut - mit Deinem größten Hammer ein paarmal fest drauf, und vergiß die Scheiße. Du hast eh keine andere Möglichkeit. Leider!
Mitfühlende Grüße Wolfgang, der als Nächstes einen Brief schreiben wird, denn dann ein Rechtsanwalt unterschreiben muß....auch so eine Drecksbande!
Posts: 11,769 Likes: 21
Posts: 11,769 Likes: 21 |
Sehr erbärmlich das die AXA Versicherung nicht in der Lage oder Willens ist einem Bestandskunden sein 110K€ Fahrzeug zu versichern. Schicken die auch alle S-Benzen und Carerra-Fahrer oder Unimog zur Konkurrenz?
Posts: 234 Likes: 5
35.10 4 x 2
35.10 4 x 2
Posts: 234 Likes: 5 |
Hallo Hartwig - ich kenne die Neubewertung nach Restauration in Deutschland. Z.B. Dekra schätzt das Fahrzeug und Versicherung setzt dann diesen Wert in die Police ein. Is ja vielleicht jetzt kein Trost - hier - auf Tene - is das alles ganz anders. Es gibt - meines Wissens nach - keine Versicherung, die ein Fahrzeug - anders als dem aktuellen Schwacke Wert versichert. Soweit zumindest die Info von Allianz - da war ich vorher. Das wäre hier nicht üblich. Da ich vorwiegend ältere Autos fahrel, war das für mich nicht so toll. Kann man halt nur aufpassen und seine Fahrweise den Bedingungen anpassen - das heist wenn viele Raser unterwegs sind - etwas vorsichtiger und bedachter fahren. Gruss Alex
148
9,901 Registrierte Benutzer |
Themen44,260
Posts671,831
Mitglieder9,901
